[Possible Fix] v5.42 - Crash when cleaning
On 4/25/2018 at 07:21, Stephen Piriform said:
<div class="ipsQuote_contents ipsClearfix">
		Hey guys, I am starting this new thread and will merge all existing reports into this one so we can collate information about the issue and work on a fix. Windows 10 was tested prior to release, so this seems like something specific to the system setup. I will post updates in this post at the top of this thread.
		This thread <strong><u>is not</u></strong> for any of the following reported issues, please use another existing thread for:
	<ul><li>
			Issues with Chrome Profiles after cleaning
		</li>
		<li>
			Issues running CCleaner on Windows Server 2008
		</li>
	</ul><p>
		This thread <u><strong>is</strong></u> for reporting and discussing the issue detailed below:
	<ul><li>
			On Windows 10, when running a clean, CCleaner crashes/becomes unresponsive
		</li>
	</ul></div>
Hi. Been using CCleaner for many years without any problem until 3-4 days ago. If I run the cleaning scan, at about mid 95-96% progress, it stops working. A pop up window that reads "CCleaner has stopped working. A problem caused the program to stop working blah blah blah..." appears with a "Close Program" button. I believe this problem started happening after a windows update around that time. I uninstalled Ccleaner, rebooted laptop, and installed a new copy . Problem still remains. I'm using Windows 8.1 64-bit. Thanks for any help in advance.
Ok, I found a quick fix below, which was for Windows 10. So the problem is happening at least on both Windows 8.1 and Windows 10. I unchecked "Mozilla -> compact databases" and the cleaner is working fine now.
https://forum.piriform.com/index.php?showtopic=47979
Hope you can release a fix soon. Thanks again.
Hi. There is a program that i can suggest to you. Its name is ??? ??? ???. Search on web you can find and start to use it. It is not complicated one. Has easygoing interface and really can be helpful if used rightly.
Hope it can fix your problems.
@cleanerjm,
v5.29 was just released which should fix the Compact Database issue.
Just installed latest update 5.42.6495 (64bit) to windows 10, and when trying to start just get the error message "ccleaner is not working". uninstalled and reinstalled still the same.
Help!!
I am having the identical problem Is there a fix for this?
I'm having the same issue as well. I renewed my subscription. When I start Ccleaner, the screen shows up and shows what needs to be cleaned, but when I toggle the clean button, the screen disappears and does not clean anything. I'm using windows 7. Any suggestions?
This thread is not for any of the following reported issues, please use another existing thread for:
  • Issues with Chrome Profiles after cleaning
  • Issues running CCleaner on Windows Server 2008
This thread is for reporting and discussing the issue detailed below:
  • On Windows 10, when running a clean, CCleaner crashes/becomes unresponsive
Identical problems,
1. PC Win10Pro, 64 bit: the cleaner runs perfectly well, no problems;
2. Laptop Win10Pro, 64 bit: the cleaner crashes, when you press the 'clean' buttom. If you 'analyze' first and than try to clean, the cleaner freezes;
3. Laptop Win10Pro, 32 bit: The 'analyze' works, the cleaner freezes.
AV-system: Kaspersky
do you have the same problem ?
i did this video for better understanding
https://drive.google.com/file/d/1_ayqOcGC8HvRTtvhhT4ku7TRZZG3PV3r/view
if it's general problem when we have a fix ?
also unsing kis 2018
@sylt21: can you please create a process dump of CCleaner.exe on your 32-bit machine when ccleaner freezes? When it happen, please run Task Manager, find CCleaner.exe process, right click and create a dump. Can you please upload dump somewhere? Thanks.
@others (64-bit users): please download procdump.zip (https://download.sysinternals.com/files/Procdump.zip), close running CCleaner UI and run procdump.exe -e 1 -f "" -x "C:\Program Files\CCleaner\CCleaner64.exe" - it should create a dump file when CCleaner crashes when you press "Clean" button.
Thanks!
19 minutes ago, pk2 said:
		<strong>@sylt21</strong>: can you please create a process dump of CCleaner.exe on your 32-bit machine when ccleaner freezes? When it happen, please run Task Manager, find CCleaner.exe process, right click and create a dump. Can you please upload dump somewhere? Thanks.
		<strong>@others (64-bit users):</strong> please download procdump.zip (<a href="https://download.sysinternals.com/files/Procdump.zip" rel="external nofollow">https://download.sysinternals.com/files/Procdump.zip</a>), close running CCleaner UI and run <strong>procdump.exe -e 1 -f "" -x "C:\Program Files\CCleaner\CCleaner64.exe"</strong> - it should create a dump file when CCleaner crashes when you press "Clean" button.
		Thanks!
i don't have crashes
you actually have -- I looked at your video (thanks for it!) and CCleaner just disappears (= crashed); you can verify it from "Task Manager" if CCleaner is removed from the list, or not
if what you say is true...i did not see anything even maintenance of windows 10 ..yes when i click clean is just like exit the program..yes is disappear from task manager...where did you see the crash ?
p.s i did install ccleaner 5.41 works perfect ..
but is strange that without kaspersky internet security 2018 in the process it works ....
this new version worked with kis 2018 but after the av update today ccleaner did no longer worked but only when you click continue cleaner close no crash dump or something like that...i did submit to kaspersky support
what could it be ?
https://forum.kaspersky.com/index.php?/topic/393838-kis-2018-update-today-25042018-close-ccleaner-when-execute-comand-clean/
Can you white list ccleaner in Kaspersky, idk I don't run it, but just spit-balling.
		Identical problems,
do you have kaspersky on all systems ? or only on one with the problem ?
sorry i did not understand you white list you mean to exclude in kaspersky interface if this your point i did this ...
can you be more specific to this problem ?
just purchased ccleaner 5.42.6495 (64 bit). I'm a computer novice. get "ccleaner has stopped working". Any workarounds?
Yes that's what I meant
Hey guys, please take the poll in this thread if you have't already done so. We are investigating this, but it's clear it's only affecting the minority of users and is linked to some environmental setup.
