Portable CCleaner
I'm using windows xp and I've installed the latest version of portable ccleaner in my usb drive.
It appears that everything is working well but when I close the program a sequence of messages appears with the following texts:
Couldn't write "(App)Start Menu Ordering" setting in INI file!
Couldn't write "(App)OpenOffice 2.0" setting in INI file!
Unregistring: CCHelper.ocx Failed!
Unregistring: CCListBar.ocx Failed!
Unregistring: CCListView.ocx Failed!
Unregistring: CCSubTimer.dll Failed!
Unregistring: CCSystem.dll Failed!
Unregistring: CCTab.ocx Failed!
Unregistring: CCTreeView.ocx Failed!
Anyone knows how to fix this?
Welcome to the forums :D
This is happening because you are using a storage device such as a CD-R that cannot be written to.
You may want to consider a flash drive or a CD-RW.
Or you can just stick with the issues ;)
That would only explain the Couldn't write... errors, but not the Unregistring errors.
My guess is insufficient user rights. In XP home edition you have to be logged on as administrator to get it work properly... Though normally it shouldn't even start if you are not logged on as administrator.
Do you always get just these errors
Or do you get a whole bunch of other write errors too? If so add in the portable.ini in [PORTABLE] section value ReadOnlyMode=1
Also could you run Portable CCleaner in debug mode (run the exe with /PDEBUG parameter or change the debug mode on with the portable.ini file) and post the log (you can copy the log text by right-clicking it) in this topic.
Thanks TheFiresInTheSky!
I'm using, as I told you before, a usb drive (a pen drive), and I'm logged as administrator.
The messages only appear when I close the program, individually, in a board, and in sequence. And it is allways the same messages.
could you please post a screenshot?
Give me your email and I send them to you
Just post your screenshots on the forum, it isn't general practice to get help via email. There are completely free image hosting services located at:
* http://www.imageshack.us/
* http://xs.to/
yes, also if you upload it there and post it here, others may be able to help you out also ;)
Sorry, I don't have the time!
just whenever you get a chance, it could even be a couple months and we will still help you with it ;)
I really want to get this problem solved before next Portable CCleaner release. :o I made a special portable.exe build what will always run in debug mode and it haves extra logging capabilities. So esponjacinzenta please try this build.
Just unzip the exe file in the same directory with all the other Portable CCleaner files and run it. It will create two log files (install.log and portable.log) in the same directory with the exe file. Attach the log files to your reply here or send them to my email *yoink* Thank you. ^_^
*yoink* Too late. <_<
Anyway to make this working in BartPE off of a CD? Possibly have it copy the files needed modifying to ram drive and executing from there. Then on exit remove temp files. Current portable.exe gives a cclistbar error and exits.
