Hi. Could any post somewhere the latest Embedded_INIs_3.06 ?
Thanks.
Thanks.
what does this have to do with Portable Browsers?
What does this have to do with HTML5?
Embedded are no longer Distributed, there is now a method for extracting them yourself
Hi there,
Please use command line to export embedded INI files.
ccleaner.exe /export [folder path]
Thanks
MrT
The problem is that I use portable browsers, and even if I extract embedded INI, I don't know what CCleaner cleans ( file names ) from a std installation. So if someone would tell me ( file names ) what CCleaner deletes after a web session with Barracuda, I could resolve the question.
Thanks.
It cleans the cache files and such, most of which is doable from the browser itself.
What Browser is Barracuda based on? Checkout Custom Locations http://www.piriform.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-clean-user-data-from-non-standard-mozilla-browsers It works for Most Mozilla and Chrome based browsers
