portable appps integration
not that the new verion of CCleaner is a single fully integrated exe file would it be possible to have an official protableapps.com release of CCleaner that integrates into the portable apps menu?
also how about a quick link on the main window for a one off file shredder for those odd files that need nuking?
thanks
hexacet
thanks
hexacet
Have you tried putting the CCleaner Portable folder in the Portable Apps Menu? I haven't yet but many portable apps I use that aren't official Portable Apps integrate perfectly into the Portable Apps Menu. Maxthon 1 and 2, Avant, Faststone Screen Capture, FS Image Viewer, and Revo Uninstaller are some examples.
