Please help someone!
Please if anyone has any information!...
Basically, I can delete my temporary internet files and clear my history folder to get rid of the internet sites ive visited.
However, when i type into the address bar, for example www.g
a list of a few old websites beginning with 'g' that ive visited appear, as a drop list under the address bar. And same goes for different letters, when i start to type in an address, a list will appear of recognised sites, from ages ago! Why does the computer remember these sites and not others? I havnt saved them in any way? My favourites do not even come up??
How do I delete these internet shortcuts?? Ive tried everything but they will not go anywhere! Please anyone with any information please help!!
turn off auto complete
launch ie
go to Tools -> Internet Options..
click on the "Content" tab and click on the "AutoComplete" button and uncheck the checkboxes...
WOW
THank you soo much really
I appreciate your reply so much. i have tried , Everything!! and i mean everything. didnt realise it was so simple!
The main problem has gone, however i did notice when i click on history; then go to search and type in letters or sites; the same list comes up. Is it possible to get rid of these sites permanently?
guy.
Have you downloaded CCleaner? If not get it here and then run it.
http://www.filehippo.com/download_ccleaner.html
Let me know if that fixes your problem. If you have already done this than also tell me.
HI
Yes I have already downloaded cc cleaner, and ran it. but no luck. the internet sites are still there.
Any suggestions?
Thanks, guy.
