Instructions:
Click Start
Click Control Panel
Click Switch to Classic View
Click View
Click Details
Click Display
Click the Desktop tab
Click Customize Desktop
Uncheck Run Desktop Cleanup, and then click OK
Click the Screen Saver tab
Choose (None) for the Screen Saver
Click Power
Change Turn off monitor to Never
Click Apply, and then click OK
Click the Appearance tab
Change the color scheme to Silver
Click Effects
Uncheck Use the following transition
Uncheck Show shadows under menus
Click OK
Click the Settings tab
Change Screen resolution to 1024x768 pixels
Click Advanced
Click the Monitor tab
Change Screen refresh rate to 75 Hertz
Click Apply
Click Yes
Click OK
Click OK
Click Folder Options
Click View
Check the following boxes:
Display the contents of system folders
Display the full path in the title bar
Display the full path in the address bar
Show hidden files and folders
Uncheck the following:
Automatically search for network folders and printer
Hid extensions for known file types
Click Apply
Click Apply to All Folders
Click Yes
Click OK
Click Internet Options
Click Use Blank, and then click Apply
Click the Content tab
Click AutoComplete
Check Forms, and then click Apply
Click the Connections tab
Click LAN Settings
Check Automatically detect settings, and then click OK
Click Setup
Type area code, and then click OK
Click OK
Click Next
Click Next
Select Set up my connection manually, and then click Next
Select Connect using a broadband connection, and then click
Next
Click Finish
Click the Programs tab
Change HTML editor to Notepad
Uncheck Internet Explorer should check to see whether it is the default browser, and then click Apply
Click the Advanced tab
Enable Install on Demand (Other)
Enable page transitions
Notify when downloads complete
Show Go in the address bar
Check the following:
Use inline AutoComplete
Use Passive FTP
Do not search from the Address bar
Empty Temporary Internet Files folder when browser is closed
Click Apply
Click OK
Click Mouse
Click the Pointer tab
Change Scheme to 3D-White (system scheme)
Uncheck Enable pointer shadow
Click the Pointer Options tab
Uncheck Hide pointer when typing
Click Sounds and Audio Devices
Check Place volume icon in taskbar
Click Sounds Tab
Choose No Sounds for the Sound Scheme
Click No
Click System
Click the Settings button under Performance
Select Adjust for best performance
Show window contents while dragging
Smooth edges on screen fonts
Use drop shadows for icon labels
Use visual styles on windows and buttons
Click the Error Reporting tab
Select Disable error reporting
Uncheck But notify me when critical errors occur, and then click OK
Click the System Restore tab
Check Turn off System Restore on all drives
Click Apply, and then click Yes
Click the Automatic Updates tab
Select Turn off automatic updating
Click the Remote tab
Uncheck Allow Remote Assistance
Click Taskbar and Start Menu
Uncheck Lock the taskbar
Check Show Quick Launch
Click the Start Menu tab
Select Classic Start menu
Click Customize
Check Display Favorites
Check Show Small Icons in Start Menu
Uncheck Use Personalized Menus
Click OK
Click Apply
Click OK
Click User Accounts
Click Change the way users log on and off
Uncheck Use the Welcome screen
Click Apply Options
Close the Window
Exit the Control Panel
Open My Computer
Right-click on the hard drive icon and select Properties
Uncheck Allow Indexing Service to index this disk for fast searching
Click Apply
Select Apply changes to X:\, subfolders and files, and then click OK
Click OK
Reboot machine, Call me in the morning.
