After doing CCleaner updates and clean-ups; I cannot right click and forward photos or documents. I get this message.
There is no email program associated to perform the requested action.
Please install an email program or, if one is already installed
create an association in the default </font><font size="+1">programs control panel.</font>
Nergal
July 28, 2019, 11:11pm
2
Did you use the registry tool? or just the cleaner?
If just the cleaner,did you use "easy clean" or "custom clean"? If the latter what settings did you change from the default (if any)?
What mail program do you use?
Unfortunately, I originally just wanted to clean but as you said it asked if other things need to be done and
I suppose, being somewhat new to computers, I ticked yes
The mail program I am using is Mozilla Thunderbird
This is the right-click "Send to Email Recipient" in Windows? Apparently Windows can lose associations after updates. This has come up a bit in the Microsoft help forums. See if this works for you:
Go to Control Panel > Programs > Default Programs > Set Your Default Program
Select "Mail" and then select your preferred email application from the list
No, that did not work. Any other suggestions?
I am still getting this message when I right click and left click on send to mail recipient:
mta
July 29, 2019, 9:09pm
7
have you tried uninstalling, rebooting and reloading Thunderbird?
Thanks for your idea. My concern is, will I lose all my information and contacts if I uninstall Thunderbird and
then reinstall it again?
mta
July 30, 2019, 2:35am
9
I haven't done that to TB for a while, but pretty sure it all remains in the current Mozilla profile directory.
but to be sure, to be sure, you could always make a copy of that folder and re-import those emails if it doesn't.
Thank-you for your help.
Let me take a few deep breaths and give it a whirl
in the next few days
9 hours ago, WheeWhilly said:
<div class="ipsQuote_contents ipsClearfix">
Thunderbird was not on the list of available email apps to select from?
Hello, Thunderbird was there and I clicked on it and retried and this same message came up:
I even went to straight mail as is recommended by Microsoft and nothing changed.
Extremely frustrating to say the least because this right click to send info is a real asset.
Other than paying for someone, it would be nice if I could just retrieve what I had before I did the
Clean-up with CCleaner.
If the PC hasn't been rebooted since that happened give it a try.
