PC runnnning sloowweerr affterr installl
After downloading/installing/running CCleaner my computer is running way slower than it already was. What to do? Uninstall and go to Norton$?
Did you clean/remove prefetch files? Were many files removed? If so, when was your last defrag? Norton? They make a cleaner?
You are comparing apples to pears
If you want any advice stano you are going to have to give information such as what operating system and service pack you have.
Did you install the yahoo toolbar?
Did you use the registry cleaner (issues) part of ccleaner?
What exactly is slow, browsing, opening files...what?
If all Norton malware protection has been replaced by CCleaner the computer's speed and response could be affected by malware.
Alan
XP-Professional, SP 3.
No.
Yes, but it states that the files have not yet been deleted and I can't seem to find how to execute that.
Browsing, opening files, everything. I click to open anything and walk away to the back of my house(approx 50 ft.)and maybe the file opens by the time I return. Sometimes on some days files open faster!
Thanks for the attention!
Sounds as though you may have either some kind of software conflict going on or a virus/malware issue.
As the virus/malware issue is the most important one you should check it out first, it may be a good idea for you to follow the steps here
http://forum.piriform.com/index.php?showtopic=20120
If you come out all clean we could perhaps have a look at what software you have running especially security software, to see if there are any conflicts.
