PC problems...
Nice work JD! :D I'm glad that you're in business and that you got the result that you wanted. Good footwork on your part too.
Good Times! ;)
Well I finally did it and it worked pretty much fine. Even stopped halfway to ask me if I really wanted to reinstall my 'unsigned' Omega drivers :D. It did corrupt my modem drivers, so couldn't connect to net to activate Windows, causing a phone call to Microsoft India, but the bloke was very efficient so no real problem. Have even copied the folder to disc for future use if necessary. Had to reinstall a load of Windows updates as expected and I now have a nice full $hf_mig$ folder (and no longer have that bloody stupid active-x update) B)
In case anyone was wondering I did some digging and it seems the Toshiba recovery disc that I couldn't access Windows from only contains a Norton Ghost image of the hard drive as was when factory installed. This is apparently standard practice with Tosh recovery cds. I downloaded the free trial version of Ghost to have a look for myself and its right, all the files installed after reformat are there exactly the same on the disc.
Thanks for all the help and advice again krit (and MikeW for the original post) ;)
Very glad all worked out for you in the end.
Mike
