I don't think it can be paused, so thanks for the suggestion Leonard. The devs take note of all, but seldom comment unless they require more info.
Just out of interest, and forgive me if I'm teaching my grandmother how to suck eggs here, but were you aware that you can control the import of duplicate files in Lightroom?
Lightroom determines a photo is a duplicate of another file in the catalog if it has the same, original filename; the same Exif capture date and time; and the same file size. You can instruct Lightroom to disregard duplicate files when importing.
In the File Handling panel on the right side of the import window, select Don’t Import Suspected Duplicates.
