Hello. Thank you for your great program, which I find very helpful.
I would like to see a function where you can pause the program and
delete the previous items and then resume the cleaner. If there is a way
to do this, I would like to know how. Thank you again for the program. victor1244
mta
2
there is a 'soft of' way.
the process can be stopped at any time, and when re-started, what has already been processed won't be there to get included the next time.
so although not a "pause, let me do something, resume", I think you end up with the same outcome.
mta, Thank you for the information. victor1244
