As the title says whenever I run the Ccleaner, I uncheck the part for "Saved passwords", but after it is finished I can see that most of the passwords I have typed in are cleared and have to type them again except my Outlook and Yahoo mail accounts.
Isn't it suppose to keep all the passwords by uncheking the part I mentioned?
Login information is also sometimes stored in flash cookies so unchecking "Adobe Flash Player" as a test may be worth a try if the above doesn't do the trick.
