Whenever I clean my computer with ccleaner my pandora.com login info disapears. I sent them an email to ask about what cookies to stop them from deleting, heres what I got back:
Pandora keeps all information about your Pandora account in Flash Local
Storage. Since this information is stored in a hidden Flash file
associated with the Flash plug-in, and not associated directly with your
browser itself, it's not technically a "cookie" in the usual sense [for
instance, Pandora account information will usually survive an
un-installation and re-installation of your browser], but your Ccleaner
program probably wipes Flash Local Storage in addition to erasing
typical browser-stored cookies.
You might want to see if Ccleaner has an option to leave Flash files
alone, or else to add Pandora.com to the 'allowed sites' list for Flash
Local Storage. You may want to read the Ccleaner help files regarding
Flash, or even send an email to Ccleaner support for assistance on how
to do this.
Best wishes,
Ian @ Pandora Media
How can I do this?
Thanks
Open ccleaner look in applications tab and scroll down and uncheck macromedia flash player under multimedia.
Let me know if that works.![:)]()
i cant believe i didnt think of that myself
but it seems to have worked
also, is there a way to disable it for one site, and leave it for the rest?
Thanks
That just sounds silly to me, why can't they just use a regular cookie ![:rolleyes:]()
I've experienced the same woes w/ CCleaner, NOT be able to selectively delete/save certain files, in the Macromedia mode..
This causes a lot of grief at times. CCleaner should be able to develop a system to attain file management re: delete/save, as is available for "Cookies" settings.
Thanxxxx..................Rudy ![<_<]()
![:huh:]()
