i was supposed to get Speccy, Recuva and defraggler but it did not load with the updated cleaner
I believe that you need to download the FREE version of each one seperately and then go to Help/Options, click 'Upgrade to Pro' and enter your 'Bundle' licence into them.
That way you only download/install the ones you want to use.
https://www.ccleaner.com/speccy/download
https://www.ccleaner.com/recuva/download
https://www.ccleaner.com/defraggler/download
eg. for Defraggler you would install the FREE version and then go to Help>About and click the Upgrade to Pro:
