I'm not sure if this is only in this version but thats somewhat irrelevant.
when "wipe free space" is selected in the main selection window and cleaner is run, it takes the same amount of time to clean regardless of the number of passes selected. i have a tiny 2.8gig partition [Temp (E:)] which houses my TIF and Cache and downloads etc, and i routinely wipe the free space with 3 passes. after updating it seemed considerably faster than previously so i decided to check it out.
it takes approx 46 seconds whether using "normal file deletion" or using "secure file deletion" with any number of passes from 1 to 35. it does, however, correctly quote the method in the post cleaning report. eg. "cleaning complete 46 seconds, Secure file deletion enabled - Very Complex Overwrite (35 passes)"
yet, if i wipe that partions free space thru the Tools/Drive Wiper route, then each increase in the number of overwrites significantly increases the clean time as it surely should, up to 1hr 15mins for 35 passes (estimated at the start and allowed to run for a couple of mins before cancelling).
therefore one would suspect from this that wiping free space thru the normal "run cleaner" operation is not wiping the free space as intended, and appears to be only using 1 pass regardless of settings, unless i'm missing something glaringly obvious, which wouldnt be a first time :s
