after downloading the new release 2.00, all my typed www addresses has been deleted from IE7, and all "run" index too in the start menu, even though I had unchecke these options.
The same settings worked fine with 1.41 which I started to use again....
The settings that worked great in 1.4 do not work in the new one, and it would be great to have the same settings "kept" same way when upgrading to new releases.
I have the same problem. No matter what I uncheck, it just does it anyway. The recently typed urls is unchecked and they disappear.
I uninstalled this version and found an exe of an earlier version and will use it until I get an answer. I have used this program for years, and this was a shock.
