opera search engine icon
hello,
I'm using last version of Opera browser, 10.53 and i noted that CCleaner delete the icon of search engine on in search bar.
How can i avoid that?
thank you to everybody
1. Are you using the latest version (2.31)?
2. Look at this topic, there's an workaround and Piriform probably is going to fix this issue soon.
thank you luik,
yes, i'm using last version 2.31
workaround works fine :)
