I press analyze and it stalls at 53%. Only way I can clean is by going directly to clean which is not what I want. I want to see what will be deleted
Please run ccleaner in debug mode https://forum.piriform.com/topic/37347-ccleaner-debugging-instructions/
And run analyze til it gets stuck. Quit ccleaner and post the log as a attachment to this thread
If I could just add an ammendment to Nergals instructions (Which are originally from 2012, last updated in 2018).
With windows 10 you no longer need to enter the full pathname, and don't need the quotation marks.
You don't even need the .exe anymore.
And you don't need to specify whether you are in 32-bit or 64-bit, CCleaner will run the correct one for your system.
Of course you can still use all the above, but you can save a little bit of typing.
The following is now sufficent to run CCleaner (32 or 64 bit) in debug mode:
Edit - The logfile will be saved in the folder where the main CCleaner program has been installed, usually C:\Program Files\CCleaner.
