Hi,
In Office 2007 it is possible to pin the most commonly used files to the MRU list.
However CCleaner clears out this list. It would be great if just the pinned items could remain.
Thanks,
Nico
Hi,
Thanks,
Nico
The easiest solution is t oexclude the following registry keys:
Software\Microsoft\Office\12.0\Word\File MRUDeleted by Disk4mat
Hello. I am new here and I was searching a way to keep the MRU in office 2007 (vista 64 bits) so I tried excluding the 6 lines above. However the OK button is greyed out for the 3 lines that don't end with "MRU" si I've only done half the job.
Do you have any idea of what I might have done wrong ? I did researches quite a lot on the forum before posting but english is not my native langage and maybe I've missed something.
Any help will be appreciated. Thank you.
Deleted by Disk4mat
Thanks a lot, it works now.
Glad that worked. With all the Office threads, Im starting to lose track of which one has what solution
