October Desktops
XP runs on a Virtual PC engine? Can't XP be run on a separate partition?
That screenshot I posted was from 7's "xp mode" that you get in the professional and ultimate versions. It literally installs virtual pc and windows xp for you.
You could install xp on a separate partition if you wanted, but what I put up is actually included in windows 7. You cant really customize the install of xp mode from what I saw, so there was no option to get a "real" xp install from it.
