nvidia cleaning> items present but not found
hello
i try to clean my w7 in order to use ssd
i have HP desktop with nvidia card
in C:\Windows\Help\nvcpl there is 174 help files (*.chm) with 5 different class
i made an entry in WINAPP1.ini (as french user i plan to delete all of the *.chm EXCEPT standard one and US one and French one)
when running ccleaner it spots the reference file, but when analysing or deleting it does not find anything
[Nvidia CPL lang -]
LangSecRef=3024
Default=False
DetectFile=%WinDir%\Help\nvcpl\nv3d.chm
FileKey1=%WinDir%\Help\nvcpl\nvwksARA.chm
FileKey2=%WinDir%\Help\nvcpl\nvwksCHS.chm
FileKey3=%WinDir%\Help\nvcpl\nvwksCHT.chm
FileKey4=%WinDir%\Help\nvcpl\nvwksCSY.chm
FileKey5=%WinDir%\Help\nvcpl\nvwksDAN.chm
FileKey6=%WinDir%\Help\nvcpl\nvwksDEU.chm
FileKey153=%WinDir%\Help\nvcpl\nvst3SLV.chm
FileKey154=%WinDir%\Help\nvcpl\nvst3SVE.chm
FileKey155=%WinDir%\Help\nvcpl\nvst3THA.chm
FileKey156=%WinDir%\Help\nvcpl\nvst3TRK.chm
why ?
(I have about 20 init entries that work, deleting other Japan, Russian or Chinese helps and so)
Why this one is not working ?
Thanks for help
You forgot the bar | prior to the file name on each of the FileKey lines.
It looks to me like you need just one FileKey entry by using a wildcard *.chm
Filekey1=%WinDir%\Help\nvcpl\|*.chm
BE SURE to run an "analyze" to check your code before you run a "clean"
Thanks
i found it
*.chm does not match the needs
this one does:
FileKey1=%WinDir%\Help\nvcpl|*ara.chm;*chs.chm;*cht.chm;*csv.chm;*dan.chm;*deu.chm;*ell.chm;*esm.chm;*esn.chm;*fin.chm;*heb.chm;*hun.chm;*ita.chm;*jpn.chm;*kor.chm;*nld.chm;*nor.chm;*plk.chm;*ptb.chm;*ptg.chm;*rus.chm;*sky.chm;*slv.chm;*sve.chm;*tha.chm;*trk.chm
it keeps standard.chm and ENGlish.chm and (for me) FRAncais.chm
i really dont need Turkish or Sweden or Arabic ones.
Thank for answer (i forgot to use the pipe)
I think the OP can't use the wildcard as there are 3 CHM files that aren't to be included.
As a side note, are there any implications in using WINAPP1 instead of WINAPP2 ?
Winapp1 will replace all inbuilt rules and show only the rules listed in winapp1
