Gravity
December 30, 2008, 8:19pm
1
Hello,
When I delete the following entrys with version 2.14.763, it always results in that I have to reinstall the program NTI CD & DVD-Maker 7.
Any suggestion.
Thank You.
C:\Program Files\Common Files\NewTech Infosystems\LiveUpdate\ResLiveUpdtEN.dll HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
C:\Program Files\NewTech Infosystems\NTI CD & DVD-Maker 7\Default HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
C:\Program Files\NewTech Infosystems\NTI CD & DVD-Maker 7\JCMDefault HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
C:\Program Files\NewTech Infosystems\NTI CD & DVD-Maker 7\WEDefault HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
C:\Program Files\NewTech Infosystems\NTI CD & DVD-Maker 7\DFDefault HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Nergal
December 30, 2008, 8:29pm
2
To answer your Question, Please Read my Signature
metalj
December 30, 2008, 10:27pm
3
Hi Gravity.
Welcome to the forum.
I suggest you to exclude those keys from being cleaned.
On the options menu, go to Exclude, then click Add Registry.
Good luck.
Gravity
December 31, 2008, 1:41pm
4
@ Nergal & metalj
I have excluded the two keys
Software\Microsoft\Windows\CurrentVersion\SharedDlls
Software\Microsoft\Windows\CurrentVersion\Installer\Folders.
That off course exclude everthing.
But is it possible to exclude for instant: Software\Microsoft\Windows\CurrentVersion\Installer\Folders\C:\Program Files\NewTech Infosystems\NTI CD & DVD-Maker 7
I have tried it, but the program won't let me.....
Thanks.
Alan_B
December 31, 2008, 7:26pm
5
In some situations the operating system may fail to understand something like
C:\Program Files\NewTech Infosystems\NTI CD & DVD-Maker 7\Default HKLM\etcetcetc
In which case it is worth trying with quotes, e.g.
"C:\Program Files\NewTech Infosystems\NTI CD & DVD-Maker 7\Default HKLM\etcetcetc"
The two possibilities are :-
Regards
Alan
metalj
January 1, 2009, 5:27am
6
Hi Gravity.
I've been trying to do that, but I can't.
I guess the program only lets you exclude keys,
not values.
So try this...
Make sure those directories exist.
If they don't, create them.
Hope this helps.
Problem solved
- I created four empty folders under C:\Program Files\NewTech Infosystems\NTI CD & DVD-Maker 7\ (Default, JCMDefault, WEDefault, DFDefault)
- There was no copy of ResLiveUpdtEN .dll, instead there was a Dutch version ResLiveUpdtDU .dll. I made a copy of this file, renamed it to ResLiveUpdtEN .dll and placed it beside the Dutch version in the appropriate folder.
Thank you all, and a Happy New Year
