Notifications won't go away on their own
We've been using CCleaner for several years and anytime a notification would come up letting me know about a particular action such as "Browser cleaned," it would fade out a few seconds later, which was great so as not to cover up part of the application windows I was working in underneath the CCleaner notification. Now the notifications stay up until I manually close each one which is annoying. Is there a way to go back to having all notifications fade out after they come up?
You could simply set it to clean the browser(s) on closing without giving the notification, you can set different options for each browser.
Unless you want to see them of course.
Better yet, i'll giveyou the fix. Next to the close x is a thumbtack click it and the notifications will fade as they once did.
EXCELLENT! Thank you for both responses Nukecad and Nergal! I've employed both suggestions. So THAT'S what that thumbtack is for!! Ha!!
Thank you again! :)
