Not sure if it's a bug or not
I recently downloaded CCleaner (free version). After running the cleaner I get the following error messages when I restart my computer. There are in fact 2. The box is titled Asus Setup and the message reads...
C:Users\Steve\AppData\Local\Temp\202913Loginiislost
the 2nd box is identical only the number is changed to 202934.
I must assume this is connected to my motherboard as it is the only thing from Asus I have on this computer
If I use system restore it corrects the problem.
This is log file(2 files? the file number changes)from your temporary folder that is in use by a scheduled Asus task.
Open the Task Scheduler.
In the window that appears, double click on "Task Scheduler Library" in the left hand panel.
Select "ASUS"
Disable or delete the entry that has anything to do with "AsusSetup.exe."
Thoroughly read through these URLs for the fix to your problem:
http://charlessocci.com/2013/05/01/on-windows-7-startup-a-popup-message-appears-cusersappdatalocaltemp-xxxxxx-log-iniis-lost/
http://www.tomshardware.com/answers/id-2349472/asussetup-error-132218-log-iniis-lost.html
http://www.tomshardware.com/forum/id-2814031/users-ray-appdata-local-temp-001228log-iniis-lost-error-win10-boot-completed.html
https://rog.asus.com/forum/showthread.php?29843-need-help-with-asusetup-log-iniis-lost
You will find more of the same if you google asus log iniis lost
Looks to me like you need to delete AsusSetup.exe which is in the Task Scheduler.
Thankyou both for responding. I tried Nukecads solution first and it appears to have worked. There were 2 entries there and I deleted both.
