After doing a defragmentation, why do I get left with 8% defragmentation on my drive C. When I defrag drive D, D goes to 0%,
- Perhaps some system files are skipped by Defraggler ? Are these files in "C:\System Volume Information" ?
the files are:
pagefile.sys SYSTEM FILE
when I tried to just defrag that one, got message:
Defrag Aborted
No files were defragmented
This operation cannot be done
- These files won't be moved by Defraggler at all.
this is ok
alternative you can also move the pagefile.sys file to drive D:, then full-defrag your drive c: and then recreate the pagefile.sys on drive c: (perhaps with fix size)
