not erase cookie
bonjour,
equal configuration: W7 32 bit ,browser (Chrome Version 29.0.1547.62 m), web page visited (http://www.adobe.com/software/flash/about/),
to the closure of Crome appears in Ccleaner, Options, Cookies, Cookies to erase: macromedia.com
-with CCleaner 4.04.4197 version of this file is deleted
-with the 4.05.4250 version of this file is the only one not to be deleted
precision, the two versions of Ccleaner have the same options checked
the problem is not blocking just incomprehensible, hoping that the next version fixes this regression in my setup!
apologize for my English
cordially
hello,
precision,
4.04 version over the scan cookies, analysis this site:
C: \ Users \ Username \ AppData \ Local \ Google \ Chrome \ User Data \ Default \ Pepper Data \ Shockwave Flash \ WritableRoot \ # SharedObjects \ FJ3K952C \ macromedia.com \ support \ flashplayer \ sys \ settings.sol 1KB
or is the famous macromedia.com file!
the new version 4.05 zap this search
to solve the problem, I added the part of Ccleaner, options include the following path:
C: \ Users \ Username \ AppData \ Local \ Google \ Chrome \ User Data \ Default \ Pepper Data \ Shockwave Flash \ WritableRoot \ # SharedObjects \ *. *
and everything is back to normal,
cordially
hello,
with the 4.06.4324 version, the problem is identical
cordially
this cookies is not delet with the 4.06 !
Having the same problem with CCleaner 4.06.4324 (running under Windows XP Home SP3) not deleting cookie macromedia.com even though both Internet Explorer and Google Chrome have Cookies ticked.
Any help to solve this problem would be appreciated.
If you click the cookie in ccleaner's cookies to remove/keep screen, what ifs the picture that is shown at the bottom of the screen. Do you have flash cookies checked in both the applications tab and also under the chrome heading?
When I click the cookie in CCleaner's cookies to remove/keep screen, the picture that is shown at the bottom of the screen is a Google Chrome symbol and a Flash symbol followed by macromedia.com
Cookies are checked in both the Windows tab under the Internet Explorer heading and the Applications tab under the Google Chrome heading.
hello,
the 4.07.639 version still does not correct the problem of cookie macromedia a screenshot to show you the icon,
greetings
Hi,
Do you have "Adobe Flash Player" checked under Applications->Multimedia?
Thanks
hello,
yes,
Thanks, we'll look into this.
Hi MrT
For information, if I revert back to CCleaner 4.04.4197 then the chrome cookie macromedia.com is cleared.
I note this is the last version before NVIDIA cleaning was introduced which may or may not be a coincidence.
Look forward to this being resolved in future versions.
hello,
problem solved with the new version 4.08 :)
thank you
