RobbD
1
Using latest cccleaner with Windows 10. v5.25.5902 (13 Dec 2016)
I have tried several things suggested but no luck. It’s not empting my recycle bin anymore.
And YES I have tried this twice now https://forum.piriform.com/index.php?showtopic=42673
Any other ideas ??
Have you tried running a system file check as admin?
(right-click on start and select command prompt as admin, and put sfc /scannow and then press enter)
Then still using cmd prompt, copy and paste text below and press enter.
Dism /Online /Cleanup-Image /Restorehealth
(have your internet connection on when you run Dis, it may take a little while and be appear to be stuck at 20% but it isn't).
RobbD
3
ok seems I looked into all settings and went to advanced.
Seems I had, Only delete files in Recycle Bin older than 24 hours, checked.
Sorry for the troubles. Maybe if others have this issue it can help them to check there settings …
No trouble Robb.
Glad to here you are all sorted now ![:)]()
