Hope this is in correct place.
The latest version is NOT clearing the Temporary Internet files in K-meleon.
I have migrated from Mozilla Firefox to K-Meleon.
Running Windows Vista
Have 3 web browsers on the Puter:
Internet Explorer. (this must stay)
Firefox (probably could be deleted)
K-meleon (new web browser)
It must be some setting that I am not aware of.
Maybe I might have to uninstall FireFox.
Or uninstall CCleaner and reinstall it after uninstalling
FireFox.
Great product. Thanks much.
Your help would be very much appreciated.
More on the same subject.
I am finding that when I sign on to this site it uses FireFox.
If I delete FireFox how will I be able to enter this site?
It appears CCleaner is tied into FireFox and FireFox only.
I will try uninstalling FireFox and try to enter this site. I'll
bet I am dead with the attempt.
Correct me if I am wrong.
Which browser is your default?
I'm not sure. I guess it depends on where I've been last.
BUT it should be K-Meleon.
I have saved my FireFox Bookmarks and am now
going to uninstall FireFox and see what Happens.
Wish me luck...
OK - part of problem solved.
Evidently there was a conflict as to which browser was the default.
FireFox has been uninstalled and K-Meleon can address this site.
If I go on K-meleon and go to the URL (where web addresses are keyed in)
and click on the triangle at the end of the URL bar I find that the last
visited sites are NOT cleared.
I have the latest version of CCleaner.
I have no idea how to solve this problem.
At this point I uninstalled CCleaner and reinstalled CCleaner.
Called up CCleaner and look on the lefthand side and went into Applications.
FireFox was not there BUT K-Meleon was not added.....
I've done all I can to solve problem.
I don't believe CCleaner is preconfigured to clean K-Keleon. Here's what I've added for KM to my 'Include' list:
C:\Documents and Settings\[user]\Application Data\K-Meleon\default\[profile name].slt\cookies.txt
C:\Documents and Settings\[user]\Application Data\K-Meleon\default\[profile name].slt\history.dat
C:\Documents and Settings\[user]\Local Settings\Application Data\K-Meleon\default\Cache <-- a folder
The above may be different on Vista, but you'll find them.
Also, on the K-Meleon menus, go to Tools/Privacy/Settings, and check both items under Address Bar History.
