I like the recent documents listings for ease of returning to a particular doc for rework. As hard as I've tried by unticking and reading forum entries, every time I use ccleaner, I lose the recent docs list.
I am using v3.12.1572,
IE9 primarily, Firefox v7.0.1 becoming less and less
If you are talking about MS Office recently opened, start CCleaner, click on the Applications tab and un-check the Office 20XX check box.
If you are talking about Recent Documents off the Windows Start button, start CCleaner, make sure the Windows tab is selected and under the Windows Explorer section un-check the Recent Documents check box.
I just tried following the advice given here before running CCleaner. My 'Recent Files' in File Explorer was full of recent downloads, etc.. I made sure Recent Documents in the File Explorer section of CCleaner was unchecked, and then I ran CCleaner. All my recent files was still deleted. I use Recent Files in File Explorer all the time, so that feature is important to me. What did I do wrong, or not do right? I don't ever want CCleaner to delete recent files.
