Not cleaning Chrome
I've noticed that when I close Chrome browser I no longer get a notification. I then run cleaner manually and it finds cache etc to clean.
It works as normal with Opera.
Make sure chrome is actually closing, background apps such as cloud print or sync, or a badly coded add-on are causes of this. Exit chrome then check task manager for any chrome processes, including chrome exe or plugincontainer.
I\ve checked, there are no chrome processes running after I close it.
Uninstalled Chrome and then re-installed it and that seems to have fixed it.
