Is it possible to get this Firefox spell check to work in topic or subject fields? Works great in message fields! Thank You!
Right-click in the field and tell it to 'Spellcheck this field'. If that option is checked already, select the option so it's unchecked, repeat it again, and it should take.
Went over to the Firefox support forums (wow is that ever getting the hits, I doubt dialup folks would ever get in) and this is how it is fixed: do the about:config thing, scroll to layout spellcheck and change the value from 1 to 2. I still prefer correcting all misspelled words at the same time as opposed to one at a time, hopefully that option will become available maybe as an extension.
