Newest version problems
Hello,
Since installing the lastest version of Defraggler on my computer, running Win XP Service Pack 3, and IE 8 all the files won't defrag. I check to see what they are, and it's a couple of .swf files from a social newwork site, that are located in the temporary internet file (the sub file created when you delete your browsing history, etc.). I manually go into the temporary internet file and this sub file is "faded out" and nothing can be done with it.
I shut down the computer for the night. The next morning, I turn it on, manually go into the cookie and temporary internet file, select all and delete and then I can complete the defrag process and the report shows 0 files, 100% complete.
Can anyone explain this?
Thank you for your help.
Harmony
Hello,
Harmony
I feel pretty sillly now that I have discovered the answer, as it is very basic. The browser needs to be cleared!
Harmony
Hey, but you discovered it yourself .... best way to learn ;)
