After running the cleaner the first time on my Dell Dimension desktop and rebooting the computer it entered the "New Hardware Found" dialog saying that the device "SDDMI2" was found.
I have no idea what this device might be and I had no luck with the autoinstall or trying the device drivers CD that came with the computer - I keep getting "software not found" errors.
I tried doing a restore of the Registry and that made no difference.
I had done quick tests of most of the computer features and don't see anything, yet, that doesn't work.
I don't have the cleaner, whatever that is, but I am having the exact same problem on my new Dell system. I found your post because I am searching all over the internet for SDDMI2 and I came across this site. Please let me know if you find out what this is.
Wow, everyone's on a dell, many on a dimension 2400! Hmm, so obviously it's a pretty specific piece of hardware...
run a search of:
C:\WINDOWS\INF
for the filename:
*.*NF
Containing text:
SDDMI2
Attach any found files so I can see what they belong to. Alternatively (or additionally), use this program and save a log file by going to List, Save to file and post whatever you can find. Thanks!
It's the driver for integrated audio. It's worth a shot. I have a weird hunch about it being AC'97-related, but maybe I'm totally wrong... only one way to find out
I had this same problem on a very old Dell the first time I rebooted after installing both the Dell Support Tool (http://support.dell.com/support/topics/global.aspx/support/en/dellsupport30?c=us&cs=19&l=en&s=dhs&~ck=mn) and a minor Windows update. I thought it might be the Support Tool, since I had no trouble with the Windows update on 2 other computers. On searching Dell's support site, I found this thread: http://forums.us.dell.com/supportforums/bo...=157240#M229202, which appears to give a solution if not an answer. If the new version of the Support Tool is causing this, I'm sure there'll be many more forums and tech support entries in a week or so.
I could have sworn I had tried deleting it and that it came back on re-boot, but after I read the notes in the Dell forum, I deleted it from the device manager device list (as suggested), and rebooted. It's gone!
Thanks, everyone, for the active help. This is a great message board!
Since I'm seeing people not using CCleaner having the problem I'll assume it was a freak coincidence that I first saw the problem immediately after running CCleaner.
I "uninstalled" the SDDMI2 device and it did not get "re-found" when I rebooted. So I'll keep my fingers crossed.
