New 5.42 Build -- Same Broke State
Good afternoon.
CCleaner 5.42.6499 is still 100% broken on systems running Windows 2008R2. One can still install the new version but when you click Run Cleaner in the running application, the application crashes 100% of the time. The issue was previously reported when the first 5.42 build was released. Prior versions (5.41, etc.) worked fine.
I believe the new build only fixes the chrome bug. If they've given the impression that the win2008 issue is going to be fixed next version (honestly can't remember what the state of that thread is) then a numbered change is when you should expect it (such as 5.42 to 5.43)
While this version doesn't break my chrome profile as the previous did, it doesn't clean the history or cache either.
6 minutes ago, cecja said:
I think this thread is about windows2008 bug. If you require help, please start your own thread; this will assure both you and the original poster get the attention due.
I tried to find proof that the hotfix was for chrome but what I thought I read today was nowhere to be found. I hope I was not wrong about that
Found it
