Nero 8 Audio
Hello all, I recently downloaded Nero 8 Trial and have enjoyed using it, I have only had it 1 week and used it alot. When I create "movie" and export for some reason it will not record the audio, when I am creating it, it has audio.
Can anyone help??
Thanks,
Dave O
If you don't get a reply I suggest the unofficial forums here
http://forums.afterdawn.com/forum_view.cfm/156
Anti-Vires my not like it not like nero 7. good help at nero, http://www.nero.com/eng/nero8-product-faq.html
# Nero MediaHome 2.0 must be installed on the server (when using the Nero Media-Streaming MCE Plug-in)
http://www.nero.com/eng/support-manuals-helpfiles.html
http://www.nero.com/eng/support-tutorials.html
Problems installing Nero 8?
Installation problems with Nero 8 are likely caused by a previous Nero version which is or was installed on your computer.
We suggest that you uninstall all previous Nero applications from your computer using our new Nero 8 Cleantool and proceed by completely reinstalling Nero 8.PS tool is free
http://www.nero.com/eng/sitemap.html
http://www.nero.com/eng/support-nero8-supported-devices.html
you can get nero to fix it,click Nero Product setup, you don't need to take off & refit.post-16440-1208478214_thumb.jpg
this is how Spybot S & D work with it all so Antivire not like may kill it look in Quarantine of AV & Spyware scaners
