needs admin rights to run?
Is there a way to run Recuva without admin rights, even if the application has been installed WITH admin rights?
Seems odd.
Cheers
Welcome to Piriform callmecheez.
Seems odd.
Well I presume it depends on what rights the installer gave it.
No you can't I've asked this question before. You need admin right to install it in the first place. I though it would be the same as CC. You don't need admin rights for that. Well you do to install it but you don't if you run it in your own folder or of a flash drive. ;)
