Need to reinstall ccleaner continuously
Hello,
Every few days I need to reinstall ccleaner, because it doesn’t work anymore. Only the following menu items are shown and the Scan now button doesn’t work:
It’s very annoying and cumbersome to have to reinstall the app everytime.
Cheers,
Pim
Hi @1974Pim,
Please let me know what version of CCleaner you are using by going to Settings> Updates, and if you are not on V7.5, please update CCleaner and let me know if you continue to experience the issue?
It happened again today. My current version is:
@1974Pim the CCleaner 7 service is not running. Please follow the instructions below to resolve the issue.
To fix this issue, you need to restart the CCleaner 7 service. To restart the service, follow the steps below:
1. Press the Windows + R keys on your desktop.
2.Type in the following text and then press Enter.
services.msc
3. If you see a prompt, click Yes.
4. In the Services window, right-click CCleaner 7 and click Properties.
5. In the Properties window, under General tab, next to Startup Type, from the drop-down list select Automatic.
6. Under Service Status, click Start.
7. Click Apply and then click OK.
Please message me back if you have any issues.
Unfortunately I encountered the same issue again today. This time it seems the CCleaner service is running:
Thank you for this screenshot @1974Pim, please generate some log files for CCleaner so we can investigate this further by following the steps below.
Please share that File ID with me so we can review the logs.
