CCleaner has identified registry items as problems.....See attached file..
Can someone help me determine which registry items are safe to have CCleaner remove....???
Thank you for any / all help.....
If those AVG Antivirus references are for old no longer installed versions you "may" be safe to remove them. But to quote moderator Nergal's signature:
DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF.Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark)
ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU’LL BREAK IF YOU DON’T.
DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF.Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark)ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T.
Just to make it so this information is clear now you can see it three times in a row.
or in other words, although very slight, and the fact CC has a very lightly-lightly approach to registry cleaning, you have more chance of 'breaking' something compared to almost no system improvement in removing those 80'odd entries.
so unless you have some sort of 'error' you are trying to sort out, I'd recommended not doing a reg clean.
a hidden fact of reg cleaning is your system may be fine after the clean but not show any weirdness for ages.
