Need information help
Hi, i use ccleaner since years and so i took a prenium key 2 months ago, but as my computer get too much problems im changing it for a new, can i use my licence key on my new computer ? as the key is for only one computer but if i delete it from my actual computer and set on new one so should work ? thanks
Yes you can simply install CCleaner Free on the new machine and then go to Options>Licence Key to enter the licence key and register it as Pro,
For ease of use you can download the installer from here: https://www.ccleaner.com/ccleaner/builds
