how can i get my sound back on my computer is there a soft were i can download for free.or something
Wildman can you give us some background to what happened to your sound?
Do you have powered speakers?
Have you checked the speaker to sound card / connection at the back of the PC?
Was the sound working before you installed or updated software?
Was it working until you powered down then restarted your PC the next day?
Are you sure that in the case of powered speakers they are plugged into the power point? and turned on?
OR are they USB powered speakers? if so, did you change USB ports?
Hello and welcome to the forum,
have you checked all the levels in sounds and audio devices in control panel just to make sure the speakers are not muted.
On another note, you might receive a quicker response in future by providing a descriptive thread title.
i think i deleted it but did not mean to and know i kant find it any were i tryed to look for it on my search eye con and it is not there what do i do i cheked all of my wires and they are ok i dont know what to do
Have you try to do a system restore?
