Lately when I click on the blue link for more information from MS on an event that is listed the Help and Support window opens but it doesn't connect to MS and there is no info in the box where you type in the terms or link to search for. This may have started when I installed IE7 Beta. However, it is IE6 that opens, not IE7.
The Help and Support Service is enabled and running in services.msc.
Anyone have any ideas or suggestions?
Thanks !
