Need help with CCleaner "Tools" that quit working
I installed the latest version of CCleaner (v3.02.1343 64 bit). All functions of CCleaner worked fine. Then I read about the winapp2.ini file, so I installed that. After doing that, the startup, system restore and drive wiper tools quit working. If I click on any of them, CCleaner hangs up with the hourglass symbol. I have to close CCleaner with task manager. I've uninstalled CCleaner, deleted the winapp2.ini file, powered down, rebooted and re-installed CCleaner. The 3 tools still do not work. Does anyone have ideas on how to fix this? Thanks.
Mark E.
I suggest you use the Portable version which ignores any malfunction in the registry.
Everything was working the first time until you did "something".
Then you uninstalled and tried to install again but it was broken.
To me that suggests uninstallation failed because files/folders/registry keys/values were added and failed to be removed.
I always suspect the registry.
Things go wrong and Windows denies access when you try to delete or correct them.
Alan
