I just recently tried CCleaner on my computer and it showed that I had
many errors etc. to fix.
I did that, made the backup as requested.
Since I used CCleaner, my daughter (who is on my wireless network) can't connect to the internet
through my computer.
I went in again and tried to find where I could restore my setting as I did save the backup but can't seem
to find anything.
Does anyone have any suggestions???
Thanks,
networkgal
go into control panel, network connections, find your connection, double click it, click properties, click disable, then click enable, see if that sorts it
