Ok, not sure if I'm doing something wrong or not. I have a 2tb secondary drive that originally got messed up. Files no longer there, but are found using Recuva. If i use basic wizard mode theres no choice for sub directories. I can do a image to another drive. If i do that that will make an exact copy with accessible files then correct?
I tried advance mode, with sub directly checked and deep scan. But theres no choice to make it go to another drive when doing that. Since the drive is so full, it errors out saying not enough room is on the drive. Thats before i even recover. Suggestions/help would be great. thanks.
