Maybe you could lend a spare drive from a friend (or another computer) to verify if the drive is defective?
Sounds a bit like it. I also lately had an LG drive that suddenly wouldn?t burn CDs anymore (behaved normally, seemed to ?write? to the blank CD, gave error upon the following verify, using ImgBurn). It was actually the drive and I had to replace it.
Another idea: Do you have DaemonTools or the like installed? I experienced problems with (older versions of the) the SPTD driver (SCSI-Pass-Thru-Driver) they install on some machines.
Thanks for your input Moonbase. I have not installed any new programs since it was working fine a little while ago, so that would not be the problem.
