Deleted by Disk4mat
Could someone be kind enough t opost an example of a working WinReg2.ini file? I created one and the items I added are visible in the registry clean section. However when scaning the registry and my custom item is checked, nothing is found. I wanted to clean the following key and subs: HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs
TIA
Download this version: http://forum.piriform.com/index.php?showtopic=1110 and extract, is working well, so you can see what's wrong with your Winapp2.ini.
Here is my ini...
[Recent Open File Dialogs]
LangSecRef=3025
Deleted by Disk4mat
[Recent Save File Dialogs]
LangSecRef=3025
Deleted by Disk4mat
[Outlook 2007]
LangSecRef=3021
Deleted by Disk4mat
Hi everyone,
winreg2.ini is currently not used for anything but features may be added in the future.
Thanks
No, it isn't working properly because in the examples mentioned the "DetectFile=" line is missing in two of them.
Deleted by Disk4mat
