Hello all,
Running CCleaner 2.31 under WinXP SP3.
I was wondering why I couldn't choose to clean Flash - it wasn't showing up under Applications -> Multimedia -> Adobe Flash Player. It turns out that I had only installed the Flash plugin into Mozilla Firefox, not the ActiveX object into IE7. The registry entry seems to be keyed to IE, since it showed up properly once I installed the ActiveX into IE.
thanks,
chris
