I'm looking to upgrade my printer so it will also print out on the top of printable CD's.
Anyone recommend one?
Cheers
Cheers
If you live in the United States visit a Staples store, they sell a Casio CD printer. I don't completely remember the price, I think it was around $50.
Whatever you do don't resort to using the stick-on labels, if you create an audio CD they eventually cause disc warpage when the disc heats up leading to skips and the inability to playback the disc once it is heated up.
If your in the UK your in luck just last week I received my Epson Stylus r200 from ebuyer which was ?59.85 and is brilliant the quality of printing on cd's is wicked and instead of 2 print cartridges it has 6 smaller ones which are like ?3 to replace so no need to replace ?30 colour cartridge if you just run out of blue etc.
