Nagging pop-ups
Is there some way to stop the nagging pop-ups that began a few updates ago? I don't want to be told that my computer needs to be cleaned of that there are non-existent updates. Is there any way to get this annoying behavior to stop?
Make sure you turn off monitoring.
Open CCleaner, then click Options > Monitoring
Disable System Monitoring by unchecking Enable System Monitoring
Disable Active Monitoring by unchecking Enable Active Monitoring.
Click Yes when the confirmation box appears
Also turn off check for updates under Options...Settings.
