MY WD Harddisk not detectable
Quote
Hi folks,
Need some help. this morning I accidentally dropped my WD Passport Ultra (External Harddisk). Post that I was browsing on the net for different options, and I came across "Recuva" as an option. I downloaded the Free version as it said "Advanced Recovery". I tried using that and followed the below steps:
Initiated Recuva Wizard
Selected "All Files" for File Type for recovery
selected "on my media card or ipod"
Then, on the next screen I checked in the "Enable Deep Scan" & pressed START.
The error message "No drives were scanned, because none matches with the filter.
Please suggest!
Thank you!
Regards,
Upendra
I asume that the drive stopped working after you dropped it.
Recovery software is meant to recover deleted files on a working drive, it is not going to fix a drive that has been physically damaged.
A good repair shop may be able to strip it down and fix it.
